Sponsored by: Auxito
Ignition Switch?
Old Jan 11, 2005 | 12:19 PM
JAYW's Avatar
JAYW
Ignition Switch?
Hi,i have a question about my 97 f150 4.6 4x4.auto.As soon as i open the left door,my chime goes off,and will sound the whole time till i start the truck.This to me doesnt sound normal.I have a feeling the ignition switch is bad and thinks the key is left in it.It seems to function properly,starts good etc.any feed-back?Thanks in advance.
Old Jan 11, 2005 | 12:54 PM
86moneypit's Avatar
86moneypit
I had a similar problem with my old bronco. The door chime will go off no matter what even if the key was not in it. The dealer told me that it would need a new ignition switch b/c it was worn out.
Old Jan 11, 2005 | 01:06 PM
PaulC's Avatar
PaulC
The chime is energized by opening the door, which means it's governed by the same circuit that works the interior lights. If the door switch for the interior lights is sticking in the on position (common on this model), the key-in-ignition system won't know that the door is closed. Try lubing the door latch (which also contains the door switch) with WD-40 and cycling the door a few times. Might be the cure.
Old Jan 11, 2005 | 01:20 PM
JAYW's Avatar
JAYW
Ignition Switch-2
Maybe i didnt explain right.97 f150 4x4.when i open the door,the chime goes off without the key in ignition.when i get in and close the door it stays on for a few seconds then goes off or if i start it right-away.if i get out and close it,chime and light go off.Thanks for the help.
Old Apr 4, 2006 | 02:18 PM
speerwurf's Avatar
speerwurf
https://www.ford-trucks.com/forums/s...15&page=1&pp=6
check out this explaination for the dinger
