Aerostar Ford Aerostar
Front End Clunk
Old Jan 11, 2005 | 11:43 AM
jjbmoto's Avatar
jjbmoto
Front End Clunk
'94 AWD Areostar
When I pulled in the parking lot at work this morning the front end made a clunking noise and was not turning easily. It happened at slow speed turning to get into a parking spot. It acted similar to a 4wd truck with the hubs locked and on a dry surface.
Any thoughts, is this thing going to make it home!?!
Jon
Old Jan 11, 2005 | 02:15 PM
RPinNEB's Avatar
RPinNEB
Clunk
The general advice seems to be to unplug the AWD computer under the
drivers seat. If the clunk goes away you probably have a sensor or
wiring problem? I'm not an expert but I drive a '91 AWD and I read this
forum a lot. If the clunk stops w/computer unplugged it is probably safe
to drive home, it will of course be a 2WD van at that point. If the AWD
light is flashing the code can be figured out here.
Old Jan 12, 2005 | 03:21 AM
himthere's Avatar
himthere
I have a 94 2wd. Had a similar situation with a clunking sound when turning into my driveway. Turned out to be my tie rod. Worn rubber on it. Replaced it, clunk disappeared. Just a possibility, your 4wd may be different.
