missing kickdown
Old Oct 20, 2002 | 06:31 PM
x_usmc_x's Avatar
x_usmc_x
missing kickdown
I just bought a 82 f150 with a 351w and a c6 tranny. I put a new Holley 600 in the truck. The truck didn't have a kickdown installed from the tranny to the carb. I got a kickdown rod from the junkyard but I don't have think I installed it right. Can someboby send me a picture of the correct install on the tranny and the carb. Can I install a cable instead of a rod?
Thanks.
Old Oct 21, 2002 | 01:58 AM
Superdave's Avatar
Superdave
missing kickdown
[updated:LAST EDITED ON 21-Oct-02 AT 03:03 AM (EST)]x_usmc_x, Does your new Holley have the provision for the Ford kickdown? Do you for sure have the right rod?
No you cannot readily use a cable for the kickdown on the C-6. Or not that I know of anyway.
The kickdown rod is usually easy to install. It just fastens to the transmission on the drivers side by the gear selector with a 1/4" e-clip if I remember right, then the same on the carburetor behind the throttle linkage. I don't think you can hook it up backwards, it should fit only one way.
Old Oct 22, 2002 | 07:22 AM
x_usmc_x's Avatar
x_usmc_x
missing kickdown
I had to buy a kickdown kit for my Holley. I might not have the right rod. Is there supose to be a bracket to limit the movement of the kickdown. If there is there was not one on my truck.
Thanks
Old Oct 22, 2002 | 10:58 AM
cdd5599's Avatar
cdd5599
missing kickdown
edelbrock sells a rod extender,
I had to make a rod extender for my truck with the new street avenger. It works great.
Chuck
Old Oct 22, 2002 | 09:54 PM
HotWhlz85's Avatar
HotWhlz85
missing kickdown
Chuck, got any pictures and/or drawings? I have a street avenger carb and am getting ready to swap a C6 in behind my 351W in place of the 3 spd w/overdrive. Any help would be appreciated.
Ron
Old Oct 28, 2002 | 12:16 AM
xuare's Avatar
xuare
missing kickdown
I have a 351w with c6 and a digital camera. Email me and i'll be happy to take a pict or 3 of it and send them on, though I still have the motorcraft 2100 carb.
ltarmstrong at covad dot net (or my listed user account email)
Old Oct 28, 2002 | 09:06 AM
Whitey078's Avatar
Whitey078
missing kickdown
Old Mar 31, 2004 | 02:00 PM
76F150390ci4x4's Avatar
76F150390ci4x4
kick down
is the kickdown rod necessary, i donbthave one on my truck?
