03 EB expy keypad code?
Old Jan 11, 2005 | 12:40 AM
atomic206's Avatar
atomic206
Help! I just bought an 03 EB but no door codes and no owners card could be found. Where are the codes located on the vehicle? or do I need to take it to a ford dealer? I was hoping to avoid the dealer but I was told that the code was located somewhere on the vehicle. Is that true?
Old Jan 11, 2005 | 06:42 AM
Xmen's Avatar
Xmen
Contact the dealer and they should be able to help you.
Old Jan 11, 2005 | 06:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
See you on the boards.
Enjoy....
Old Jan 11, 2005 | 11:36 AM
PaulC's Avatar
PaulC
In the pre-2003 days, Ford would place the code on a sticker found under the dashboard. 2003+ is a different animal.
Old Jan 12, 2005 | 12:23 PM
Triboy's Avatar
Triboy
I had the same issue last year when I purchased my used 03 but I was able to find the code. You'll need a flashlight. If you look up under the dash on the passenger side you should see a black box with 5 digits either on a sticker or stamped on it. I'm trying to recall but there may have been two boxes that could fit that description but it is one of them. Hope this helps.
Old Jan 13, 2005 | 12:04 PM
atomic206's Avatar
atomic206
thanks a bunch. I found it and it works great!
