95 problem
Old Jan 10, 2005 | 10:44 PM
32v's Avatar
32v
95 problem
My son has a 1995 f150 4x4 with the inline six. When he trys to start it he gets one clicking sound from the starter. I checked the battery and it seems to be o.k. Also checked all connections and they are tight. So, I'm thinking bad starter. Thought I would check with anyone else who might have had this problem. Thanks in advance.
Old Jan 10, 2005 | 11:49 PM
Popa Tim's Avatar
Popa Tim
Clean the grounds esp on the body, frame, and engine, then Jumper the relay on the pass fenderwell and see if she turns over.
Most parts places will test starters for free and they are not hard to take out which isn't a bad idea since the starter gets ground thru the mounts on the engine, with it out you can clean them up too.
good luck!
Popa Tim
