Modular V10 (6.8l)
Tailgate down = better MPG?
Old Jan 24, 2005 | 08:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, CVT is around now - it's available somewhere, can't remember.
Thing is, if built right, it will hold together better than the first AOD's, E40D's, etc. etc.
I think for the tailgate down reluctance on the part of the manufacturer, they don't want the liability attached with losing a tailgate because they said the MPG would be better with it down (or contents of bed, etc)...
Old Jan 24, 2005 | 09:19 PM
pops_91710's Avatar
pops_91710
Oh, brother!! Everything has to have an alterior motive. Couldn't it be because it's the truth.... maybe? I doubt Ford is worried about their liability.
Old Jan 25, 2005 | 11:09 AM
ken04's Avatar
ken04
Ford 500 has CVT, Audi, a few other makers have it. Subaru tried it quite a while ago with the little Justy, remember that car ? That bad thing is that for us gearheads, who love the sound of a big block Mustang wailing down the quarter mile with a top loader being stirred with gusto is the CVT has no gear changes. There is a manufacturer that has programmed in what feels like gears into their CVT. The motor theoritically should be in the fat part of it's range all the time, to be most efficient. But then you get that 'motorboat' sound with no variation of rpm. I had a 59 Buick with the twin Dynaflow or some cockamamie-called thing in high school. It had twin turbines (so Buick said) in the transmission that had vanes that constantly changed pitch to change gearing. Nail the throttle and the engine jumped to 4000 rpm (or so) and stayed there, until you got to cruising speed then you would back down the throttle and the trans would re-vane and you'd go into a regular cruise type feeling. But man it was weird for a while driving that car. The CVT's which are nowhere close to the same design work sort of the same though, keep the engine in it's optimal rpm range and adjust the gearing continually. Me ? I hate it, but then I like to push in the clutch and pull the handle into the next gear, peace, Ken
Old Jan 25, 2005 | 11:40 AM
krewat's Avatar
krewat
You better go talk to some corporate lawyers for a while - you'll find there are all sorts of things related to liability that they will not touch or over-document to death.
And, actually, I was saying that with some sarcasm, I wasn't being serious
Why do drug companies make these really nice commercials and then list every side-effect? Because if they don't someone will sue them because they didn't say it caused heart-attacks. It's all about liability...
Old Jan 26, 2005 | 06:46 AM
captainsstable's Avatar
captainsstable
closed gate
closed gate creates high pressure (similar to top of an airplane wing) thereby creating lift (reducing weight)
does lighter vehicle get better fuel economy?
Old Jan 26, 2005 | 09:31 AM
krewat's Avatar
krewat
Conservation of Energy gets in the way - it's not going to help MPG to increase drag, even if it lifts the vehicle - the only savings would be rolling resistance on the rear tires, and the savings would be offset by the increased power needed to provide the lift.
Even if the tailgate produces a "high-pressure area in the bed", that extra drag is going to bring DOWN mpg. There's no getting around entropy (loss/friction).
It's obvious to me, with a cap on the bed, and without, there is a 1-2MPG difference with my '01 V10 SuperCab ShortBed. I've done it 7-8 times for over 250 miles one way, and each and every time, I see 13.5-14MPG without the cap, 15-16MPG with (as long as I don't exceed 75MPH on level ground too much).
I have never tried running without the tailgate... however, I'm going to theorize a little and say that without the tailgate, you'll still have a LOT of turbulence behind the cab and in the bed, and you wouldn't see as much of an MPG improvement as a cab-height cap would give.
I have an ARE cap, it's one of the models that is more aero-dynamic, so there might be an advantage to what kind of cap you have too...
Old Jan 26, 2005 | 09:41 AM
Daryl Hunter's Avatar
Daryl Hunter
My dad called the CVT the Salsbary (sp?) drive after some motor scooter that had it when he was a kid back in the '40s or there abouts.
Our snowmobile had one in it back in the early '70s. I must say that it was kind of neat watching it work and for performance it seemed to work well too. They used a rubber belt that ran on two pulleys, one which contracted and the other which expanded - net effect was a continuous change of ratios like a smooth version changing front and rear sprockets on a bicycle.
The problem was that as the drive belt wore down in width you lost top end because it would no longer climb the front pulley as high.
Old Jan 26, 2005 | 10:03 AM
Fredvon4's Avatar
Fredvon4
Tail gate down or up does not make any mpg difference on my last two superduty trucks. Both got/get 1-3mpg increase with a coverd bed. One with cover and one with a cab height cap. Got a buddy with same truck and a Higher than cab height cap. It cost him 1mpg he says.
Daryl Hunter our 70s SkiDoo only one pully that did the in out dance. Would have been cool to have both do it. And yes they ate belts very fast. Royal PITA to change too.
Old Jan 26, 2005 | 11:08 AM
ken04's Avatar
ken04
It hasn't changed much, snowmobiles still use them, belt technology is better but it still wears belts out. The cars have a metal toothed belt that is made of flat links, it's technology is pretty cool, but it's not much different than the Salisbury drive your dad had on his scooter, and what has been on snowmobiles forever. Time will tell what will wear out first on the new style, the pulleys or the belt. Ken
Old Jan 26, 2005 | 11:42 AM
Daryl Hunter
Now that you mention it, it probably was only the one pulley that moved. It was the front one off the crank and would squeeze in as the revs increased. As the belt wore it wouldn't ride as high on the pulley and you lost some of the top end ratio.
The other problem that I remember with it was that the nut that held the assembly together was always wanting to loosen up. So my dad put some Locktite on it. Unfortunately he used the stud setting grade versus the normal blue colored liquid. When the time came to change the belt there was no way that we could get it off without an impact wrench
Old Jan 26, 2005 | 02:24 PM
Fredvon4's Avatar
Fredvon4
Sorry for the hijack FYRETEK
Daryl Hunter keeps dragging me back memory lane.
Too funny, my dad did the exact same thing and the next time we did a belt change I had to hold the propane torch while he beat the end of a breaker bar with a hammer (no impact wrench for my Dad, that would be cheatin!)
Oh yea leave your gate up and drive like the wind SuperDuty Gas trucks love to run! In 5 years I have not seen one single majic mpg adder except air in the tires!
Old Jan 26, 2005 | 03:32 PM
txag's Avatar
txag
There are two factors at play here, and the answer depends on which
factor outweighs the other.
The first is the added weight that having the tailgate down puts
on the rear tires. More weight means better road contact.
The second is wind resistance. You might think that having the gate
up creates resistance. And it does until a certain point, at which time
a pressurized pocket of air is formed in the closed bed. The outside
air flows more smoothly *over* this pocket than it does flowing over
the cab bed (as it would if the gate were left down or off).
So, whether the benefit of the added weight distribution gained by
having the gate down outweighs the benefit of having the air pocket
when it is up is the question, and this can only be borne out by
experimental testing. That is, drive each way and check your milage.
I believe it has been published that having the gate up, when driving
on a good dry road, offers a slight advantage in milage. I do not know
whether this would be true under wet conditions, where tire-road
contact is otherwise weakened by the water.
Old Jan 26, 2005 | 03:40 PM
  #28
txag's Avatar
txag
Lift is caused by high pressure on the underside of an airplane wing.
In the case of the truck, the pressure is on the upper side, thus
creating the opposite of lift.
In any case, lift is not changing the weight on the truck,
and it still takes the same amount of energy to move that mass.
What it does effect is the coefficient of friction (grip) of the
tires to the road. You get better grip, and less rolling slip,
the higher the weight on the drive (rear) tires is. This isn't
changing the weight of the truck, just the amount of
force on the rear tires.
Old Jan 26, 2005 | 07:20 PM
  #29
Daryl Hunter
Mixing weight and mass in the same sentence and making me think . . .
Depending upon how much traction you need, having some lift to reduce the downward force on the truck might reduce the rolling resistance slightly.
I think though that the lift would come at the expense of drag since nothing's free and it is going to take some power to lift a 7000 lb truck enough to decrease the rolling resistance.
Then there's trying to turn with less downward force on the tires - not good.
Probably better to pump up the tires as someone else said, then keep the tailgate up, fold in the mirrors, remove the external antenna, and start cleaning up the air under the truck.
What I wonder is how much a spoiler in the bed of the truck would help move air around my toy hauler - tag not 5vr - and save some fuel . . . ?
Old Jan 26, 2005 | 09:37 PM
  #30
krewat's Avatar
krewat
Less rolling slip? It's more like more rolling resistance - there's not much slip, just the amount of friction required to move the tires. It's not slip, but power suckage
