fuel pressure regulator question
Old Jan 10, 2005 | 05:25 PM
Mic_bug's Avatar
Mic_bug
Lightbulb fuel pressure regulator question
RE 1994 Explorer V6 4.0l
I have a fuel pressure regulator question.
Having some not so frequent stumbles right after starting my truck, but not quite stalling I decided to check my fuel pressure.
At idle with vacuum line connected I get 30-31 psi.
If I disconnect the vacuum line it goes to 40 psi.
Seems a bit marginal to me…should I spend the dollars on a new regulator.
Fuel pump and filter were replaced about 8 months / 8.000 miles ago.
Old Jan 11, 2005 | 12:03 AM
Dialtone's Avatar
Dialtone
Numbers you posted are in line with the Haynes manual figures. Looks like your pressure regulator is OK when running and if it holds pressure when vehicle is shut off.
Stumble problem most likely IAC related. See the sticky at the top of forum for cleaning instructions.
Dialtone
failsatheals
1997 - 2003 F150
Jun 21, 2016 09:03 PM
Demonhawk
Oct 8, 2015 05:00 PM
CharlieLed
Oct 1, 2015 07:51 PM
390Highboy
Jan 1, 2014 07:53 PM
tgore3
45
Jul 21, 2009 12:02 PM
