Idle question, also computer problem
Old Jan 10, 2005 | 04:58 PM
IBLDBLUE's Avatar
IBLDBLUE
Hi, I am new to the forum, but I do have a serious problem with my 92 F150. It started with a high idle, and has been a thorn in my side since. I have replaced my IAC, TPS, ECT, and throttle body gasket. I have done voltage checks on all sensers, and all but the new TPS is giving me problems. The TPS reads about 2.6. Even though it is a new TPS... So, then I put it on a code reader and I get codes 411 and 412.
411: cannot control idle at high revs
412: cannot control idle at low revs
I have been looking for other vacuum leaks and am still at a loss.
HELP
Old Jan 10, 2005 | 05:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
Enjoy FTE …..
Old Jan 10, 2005 | 08:36 PM
IBLDBLUE's Avatar
IBLDBLUE
I guess I am not the only one that doesn't know what to do
Old Jan 10, 2005 | 11:51 PM
IBLDBLUE's Avatar
IBLDBLUE
BUMP BUMP CAn't anyone help
Old Jan 11, 2005 | 12:13 AM
the peppermint's Avatar
the peppermint
sorry man, nobody i asked knows anything about the problem you are having
Old Jan 11, 2005 | 05:39 PM
IBLDBLUE's Avatar
IBLDBLUE
Is it possible that there still is a vacuum leak somewhere? Or could it just be the computer is sending an outrageous signal to the TPS?
Old Jan 11, 2005 | 06:37 PM
the peppermint
with some of the earlier computers, sometimes the only thing you can do is go to a good shop or even the dealer
Old Jan 11, 2005 | 06:50 PM
IBLDBLUE's Avatar
IBLDBLUE
Bummer, I hear flashing these computers are pretty expensive
