AMP light
Old Jan 10, 2005 | 04:49 PM
downdeephuskyjerk's Avatar
downdeephuskyjerk
AMP light
I am having a problem with my truck. The battery started to go the other day when i was driving, it did this a year ago and i replaced the alternator and battery. Well this time i checked the battery GOOD 12.43 vdc. Checked the alternator while truck was running battery has 11.56 vdc. So i say oh well needs another alt. Go get one install same thing. What else could be causing my problem. I drive a 93 f-150 4.9L 4x4. AMP light is on and truck will die after driven a few miles . Thanks for any info.
Old Jan 10, 2005 | 05:59 PM
Mil1ion's Avatar
Mil1ion
Voltage regulator ?
That 11.56 was at idle.
Idle means nothing.
What did it read at 800+ Rpm after the voltage reg cuts in ?
Old Jan 10, 2005 | 06:15 PM
downdeephuskyjerk
No change 11.36 vdc now. I have always had something like 14+ vdc even at idle if I remember right.
Old Jan 10, 2005 | 06:18 PM
Franklin2's Avatar
Franklin2
Does your truck have an external regulator or an internal regulator? If external, you can check the "f" wire and see if it has voltage on it.
You can also take a voltmeter reading from ground to the output terminal on the back of the alternator with the truck off. If you don't get 12 volts there, you may have a fuse or fusible link burnt out in the output wire from the alt to the starter relay terminal.
Old Jan 10, 2005 | 06:34 PM
downdeephuskyjerk
I believe it is internal.
Old Jan 10, 2005 | 08:27 PM
Franklin2's Avatar
Franklin2
Well, try the voltage check on the back of the alt to see if the main output wire is good to the battery.
Old Jan 11, 2005 | 07:16 PM
downdeephuskyjerk
I'm learning this all on the fly, not sure how to check the output terminal of the ALT. Would that be the high voltage harness with three wires? The other harness is the voltage reg correct? I checked all fuses, but am having trouble finding a fuseable link where might i find this?
Old Jan 11, 2005 | 07:31 PM
Franklin2's Avatar
Franklin2
If you have an internal regulator, then your wiring should look something like the diagram below.
You can see the fusible link is called "j". The black/orange wire should be one of the thicker ones, and if you can read 12 volts on this wire where it hooks to the alternator, then the fusible link is good, since the black/orange is hooked directly to the battery + via the fusible link. I don't know exactly where this fusible link is, but if you follow the black/orange wire up from the alt, you should run into it somewhere along the way.
Fordteamone
Electrical Systems/Wiring
Aug 26, 2013 10:02 AM
drivembig
Oct 9, 2012 06:52 PM
powerstroker100
Jun 27, 2010 04:51 PM
Cruickie
19
May 19, 2010 07:28 PM
2004lariat
Mar 8, 2004 07:28 PM
