Sponsored by: Real Truck
Looking for tach wire
Old Jan 10, 2005 | 04:30 PM
Bruce's Mr. Fix-it's Avatar
Bruce's Mr. Fix-it
Unhappy Looking for tach wire
2003 F250SD 5.4, is there a tach wire splice point inside the vehicle around the fuse block? I'm installing a Ford keyless entry/remote start and can't get the system to learn the tach signal from under the hood injector signal connection.
Bruce
Old Jan 10, 2005 | 05:32 PM
FortyFords's Avatar
FortyFords
Bruce
Yes there is ,you need to find the customer access wires under the dash.
There should be a group of dead ended wires with shrink tubing on them from the factory.remove the fuse panel ,look to the right following the harness bundle over towards the radio.they are tied back with a tie wrap
You want this wire (Light green with a white tracer) ,That is the CTO (clean tach output)
Rich
Old Jan 10, 2005 | 05:41 PM
Bruce's Mr. Fix-it
Thanks Rich, I'll look for it in the next couple of days.
Bruce
Old Jan 11, 2005 | 10:04 AM
ridered29's Avatar
ridered29
I am getting an aftermarket remote start on through a local stereo shop and they spent several hours trying to find the tach wire for signal with no luck. They are now going with another brand that they claim doesn't need the signal? I hope they know what is up!
Old Jan 11, 2005 | 04:53 PM
Bruce's Mr. Fix-it
Good luck, I haven't had time to look for it yet.
Bruce
Old Jan 11, 2005 | 05:27 PM
Greg250's Avatar
Greg250
On most aftermarket remote starts you can turn off the tach signal. Just make sure you program the starter engagement time or you will end up with a burnt starter.
Old Jan 11, 2005 | 08:33 PM
Bruce's Mr. Fix-it
I was going to do that, but I can't get it to go into that option bank for some reason, it stops at bank 5 and won't go to 6,7 or 8.
Bruce
brucewon
May 19, 2023 02:59 PM
bruce51d
Jun 10, 2010 01:12 PM
bruceatlom
1978 - 1996 Big Bronco
Feb 12, 2008 06:35 PM
Bruce in SC
Mar 2, 2002 05:49 PM
OABandit
Oct 30, 2001 06:55 PM
