Sponsored by: Real Truck
2005 Strobes Install
Old Jan 10, 2005 | 02:07 PM
QPS's Avatar
QPS
Smile 2005 Strobes Install
Any ideals on where and how to drill the new headlight housings for strobe tubes, the jeweled housing is seperate from the black housing and I don't want to screw anything up. I want to install two tubes in each front housing and one in each rear turn (no problem for the rear) many thanks.
Old Jan 10, 2005 | 08:30 PM
1olddog2's Avatar
1olddog2
i put them in mine a month ago, in the front lights i put them in the lower part next to the parking light, use a 1in bit (paddle or round hole saw) these ARE 1pc lights what happens is once u carefully drill thru some of the crap will fall in to sealed part so dont alarmed and dont filp the around to much either.( the top and bottom are not spreate) the trick to get the crap out is to us a shop vac .y do u want two in each housing??
Old Jan 10, 2005 | 08:41 PM
QPS's Avatar
QPS
was thinking that the headlight area and parking light area are seperated and I got a deal on a 180 watt power supply, so was looking for at least 6 strobes to run 2 sets in front and one set in rear. those upfitter switch's are great.
Old Jan 10, 2005 | 08:56 PM
1olddog2's Avatar
1olddog2
i tought that too ,but they r not seperate i had that black crap up & down i run 1 in each parking light(20 watt) and theymuch brigter then my 03 with the same exact set up . if u go two in each that would to cool to see u just got to set yuor timing right. in rear i put mine next to to back up lights.
Old Jan 10, 2005 | 09:06 PM
QPS's Avatar
QPS
Talking
I could run up to eight stobes, I got a whelen ISP 180 watt power source, but I think I'll just run the 6. it should look like a christmas tree when I hit the switch
Old Jan 10, 2005 | 09:12 PM
1olddog2's Avatar
1olddog2
i here that i get lot of commets when in plowing with them blasting away. also use some chalk on them to keep out water they will fog up if not. do u plow ??
Old Jan 10, 2005 | 09:41 PM
stevedinha01's Avatar
stevedinha01
you want to talk christmas tree you should see my truck!!! i have 3 amber pairs in the grill 2 amber pairs in the rear window, strobes in the headlights and taillights a traffic bar underneath the tailgate and 2 mini strobes under the tailgate. i get them all going when i am plowing. people love them, i get a lot of compliments!!
Old Jan 10, 2005 | 09:44 PM
Hardware's Avatar
Hardware
Chalk ??? Fill me in.
Old Jan 10, 2005 | 09:46 PM
Hardware's Avatar
Hardware
Ok figured it out.... Caulk !!! sorry, my bad.
Old Jan 10, 2005 | 10:21 PM
QPS's Avatar
QPS
Thumbs up
Man...you would need three batteries just to run those things....just kidding bet it looks cool, I may wire in a couple to my turn lights in my boss plow, the only thing that drives me crazy is when plowing with them on everything looks like its going....in....sloooooow mooootion....
Old Jan 10, 2005 | 10:26 PM
stevedinha01
hahaa actually all the ambers are led's so it draws very little power. very bright too
Old Jan 10, 2005 | 11:20 PM
1olddog2's Avatar
1olddog2
i also wired my plow head lights to my up fitters, add hitch monuted back up lights and a amber light light bar up top with work lights
AngeloCosma
2004 - 2008 F150
15
Aug 12, 2008 02:19 AM
add2255
Feb 7, 2008 05:54 PM
ccoram
Jul 7, 2005 12:17 AM
the dude
Electrical Systems/Wiring
Dec 31, 2003 10:49 PM
