1978 - 1996 Big Bronco
Steering trouble on '82
Old Jan 10, 2005 | 11:28 AM
gskett's Avatar
gskett
Exclamation Steering trouble on '82
Recently had rear u-Joint replaced and alignment done. Strainght and quiet again! BUT!!! Now the steering will "lock" around a corner and i have to 'bump' it back into a straight position!!! The steering has never failed and my fluids are ok. Is this is a big problem?
Thanks
Old Jan 10, 2005 | 11:46 AM
justshootme84's Avatar
justshootme84
I would take a close look at the steering shaft for any slack in the rag joint, and then re-check the drag link and tie rod ends. Sounds like you get in a bind somehow at full lock. When it does this again, you should be able to see where the steering linkage is stuck.
Old Jan 10, 2005 | 05:32 PM
bertha66's Avatar
bertha66
If you don't see anything in the linkage like justshootme84 says it my be a tooth chiped in the box, I had one do that a few years ago.
Old Jan 11, 2005 | 12:25 AM
aurgathor's Avatar
aurgathor
How'bout backing out the adjustment screw a bit?
