Sponsored by: Auxito
4.2 pcv line
Old Jan 10, 2005 | 10:51 AM
neil52's Avatar
neil52
4.2 pcv line
Just finished installing factory rebuilt 4.2 in my 97 f150, got done and realized I had not installed the pcv valve and tube, now I can,t find the connection to the intake, need to know where it is and can I install it without removing the upper intake manifold. Any body know?
Old Jan 10, 2005 | 11:29 PM
Racerguy's Avatar
Racerguy
Hi Neil and welcome to the forum
Did you get it figured out?
If you stick the PCV valve in the hole in the valve cover it probably will be fairly easy to figure out where the hose will reach to.
I might be wrong but I think it goes in the area under and behind the throttle body.
I haven't had a 4.2 apart in a while so I forget.
Old Jan 11, 2005 | 01:32 PM
neil52's Avatar
neil52
found it
Right where you said, had to pull the upper intake to run the line. Thanks. Neil
Old Jan 11, 2005 | 08:58 PM
Racerguy's Avatar
Racerguy
You should be good at removing and installing your intake now
What happened to your old engine?
Old Jan 12, 2005 | 06:24 AM
neil52's Avatar
neil52
I think I lost a bearing,I bought a running assembly from Ford so I didnot tear down the old engine. The oil pan was full of metal shavings,terrible knock, and when I drained the fluids to return the core oil pan had a lot of antifreeze in it.
