2004 Explorer Fluid change
Old Jan 10, 2005 | 09:37 AM
zoysia's Avatar
zoysia
Is there a way to change fluid on a new explorer that has no dipstick? Does anyone know of aftermarket tools or how it is done?
Randy
Old Jan 10, 2005 | 12:02 PM
Casey's Avatar
Casey
HERE is a method that was written for the bigger trucks. It would have to be modified a bit for your since you don't have a dipstick.
To fill the trans you need to remove the drain plug from the pan. Remove the inner plug that has an Allen hex, not the external hex. You will need a pump of some sort to pump the fluid in through this opening.
The easier way is to go to a place that has a fluid exchange machine. Many dealers and quick lube places have them.
