Stumped
Old Jan 9, 2005 | 03:15 PM
Doug300's Avatar
Doug300
Unhappy Stumped
I have an 84 150 300 1bbl..Problem is its missing/stumbling real bad..will barely idle sounds like it has like a .600 lift cam in it..it will accelerate fine although you can still feel the stumble..I have replaced cap,rotor,plugs and wires and put a new fuel filter in it this morning also have ran carb cleaner through it no change..Unplugged O2 sensor made no difference and took egr off and cleaned it also choke seems to be working fine. Anyone have any suggestions what else I could check?
Old Jan 9, 2005 | 05:37 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
Enjoy FTE …..
We are pleased you have chosen the best source for Fords!
See you on the boards.
Old Jan 9, 2005 | 10:06 PM
bigbrown84truck's Avatar
bigbrown84truck
try checking all ur vacume lines and make sure none of them are cloged or leaking
Old Jan 10, 2005 | 09:13 AM
5_labsownus's Avatar
5_labsownus
I would think the it is the carb after a tune-up and checking vacuum and intake leaks. The 1bbl carb is known for "going south" at the wrong time and without warning.
Old Jan 10, 2005 | 09:19 AM
oldhalftons's Avatar
oldhalftons
grad the carb and see if it wiggles side to side.
there are a couple screws on the bottom of the carb that like to loosen up and cause a big vacuum leak.
Old Jan 10, 2005 | 12:28 PM
Sam_Fear's Avatar
Sam_Fear
could be intake manifold too? Vacuum leak is an easy check. While the engine idles, take carb cleaner and spray around the outside of the carb and manifold - anywhere there may be a vacuum leak. Listen for a difference in engine RPMs.
Old Jan 10, 2005 | 11:05 PM
Doug300's Avatar
Doug300
Angry Still Stumped
I went thru every vaccuum hose and everything. No leak. Im almost convinced that the carb is causing the problem. Thank you for all of the input guys !
Doug
Old Jan 11, 2005 | 12:09 AM
the peppermint's Avatar
the peppermint
i had the same problem on my 84 300I6, just had to get the idle mixture screw and the timing set right, truck runs great now
