Modular V10 (6.8l)
True Duals?
Old Jan 9, 2005 | 12:03 PM
V10 Timbo's Avatar
V10 Timbo
True Duals?
Has anyone tried running true duals on the V10? I have pretty much came to the same conclusion as everyone else on trying to modify the single system. Mine sounds as good as I think it can at this point but still "SCREAMS" when you push it. It also has that 1200-1500 RPM load drone in the cab. That has gotta go! Currently running a full length system with a Summit 3" turbo and a test pipe.
The test pipe was just out of curiosity to see what change it would make. That is when the drone started but did make it much deeper and less raspy.
Old Jan 9, 2005 | 12:16 PM
73Fastbackv10's Avatar
73Fastbackv10
Yes, v10klzz71s has true duals on his truck. He uses a crossover pipe and headers as well, I believe. Check out his gallery.
