Sponsored by: Auxito
97 Electrical problems
Old Jan 9, 2005 | 02:19 AM
mattshane's Avatar
mattshane
Unhappy 97 Electrical problems
I have a 97 F-150 Ext Cab. I have electrical problems ranging from the overdrive not working to GEM module getting wet and cuasing the truck to do wierd things. I know that I have a leak on the drivers side of the windshield. I was just wondering if anyone ahs similar problems and if it causes damage to other components. Any info would be helpfull. Thanks
Matt
Old Jan 9, 2005 | 08:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource! The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
We are pleased you have chosen, the best source of Fords…..there is!
See you on the boards.
....MOVED....
Old Jan 9, 2005 | 11:28 AM
Racerguy's Avatar
Racerguy
Hi Matt and welcome to the forum
Quite often when the windshield leaks it will ruin the GEM and the fuse box. The GEM is attached to the back of the fuse box. Common problems are the heater staying on, 4x4 problems, power window problems etc.
The most important thing is to get the windshield resealed before replacing any parts so it doesn't happen again. Any glass or body shop can remove the windshiled and reseal it.
If you do a search in here you'll find more posts about this problem.
Old Jan 10, 2005 | 05:04 PM
mattshane's Avatar
mattshane
Thanks,
I'll get the windshield fixed and then get a new GEM. Thanks again for you help.
Matt
