1978 - 1996 Big Bronco
Wheel Studs
Old Jan 8, 2005 | 08:07 PM
jacque_strap's Avatar
jacque_strap
Wheel Studs
I can't seem to get the wheel studs to snug down on my new rotors. Is it ok to use some lubricant to put them in?? THanks.
Old Jan 8, 2005 | 08:43 PM
greystreak92's Avatar
greystreak92
When I put new rotors on mine, I had the same difficulty. They would only seat so far and they just seemed to stop. I used a couple of old wheel spacers (borrowed from my brother) and the wheel lugs run on backwards (so the flat side was against the wheel spacers. using the same method as I would to install the wheel I tightened the lugs until they had drawn the studs into the rotors the last little bit. Removed the lugs and spacers and continued installing the new rotors.
