Steering Column wiring?
I am hooking a 73 column in my 69 so if someone know the colors on the 73 column that would help.
If some one know where on the net I could get this information that would be great. Thanks for your help.
John
67-72 steering column pin out.
Big Connector:
White/Blue stripe: Right Front Turn Signal/Indicator on Instrument Panel Green/White Stripe: Left Front Turn Signal/Indicator on Instrument
Panel
Blue/Yellow stripe: Ground When horn Depressed
Red/Black Stripe: Brake Pedal Switch (12 VDC when brake pedal is depressed.
Blue: Turn Signal Flasher (Provides 12 volts to Turn Signals) Little Connector:
Green: Right Rear Turn Signal/Stop Lamp
Yellow: Left Rear Turn Signal/Stop Lamp
Connect the following color wires together.
White/Blue Stripe on steering column: Connect to White/Blue Stripe on big connector Green/White Stripe on steering column: Connect to
Green/White Stripe on big connector Black/Red Stripe on steering column: Connect to Red/Black Stripe on big connector Blue on steering
column: Connect to Blue on big connector Yellow/Black Stripe on steering column: Connect to Green on little connector Light Green on
steering column: Connect to Yellow on little connector
