Voltage Problem
Old Jan 8, 2005 | 01:48 PM
beez82gt's Avatar
beez82gt
Voltage Problem
96 f150 I6. trucks runs and starts ok, when i get to a stop sign lights go dim and gauge drops. i tried shutting everything off i.e. heat, radio etc... doesnt make a difference. tried 3 batteries all the same. voltage when engine off , just over twelve. engine running= 14.8 or 9. is that too high. is my voltage regulator gone, cant find any loose grounds. all conections are clean. any suggestions?
sorry i forgot one symptom: gauge seems to go up after extensive driving or driving 100klm/ hr plus, like it is over charging. help!
Old Jan 8, 2005 | 09:53 PM
Franklin2's Avatar
Franklin2
Your voltages look good. You may want to check your idle speed. If it's too low, you might want to take the throttle body and IAC valve apart and clean all the crude out of the passages and the throttle butterfly and see if that helps.
