1996 explorer brakes
Old Jan 8, 2005 | 10:07 AM
hill2523's Avatar
hill2523
I have a 96 explorer all wheel drive, I am wandering if the rotors have bearings or are the rotors just take on take off kind?
Thanks,
Hill2523
Old Jan 9, 2005 | 08:22 PM
2Mac's Avatar
2Mac
They are just the take off kind ,Front and Back but you might have to pursuade them if there is alot off rust.
Old Jan 10, 2005 | 01:09 AM
EXPL4X4's Avatar
EXPL4X4
Strange parking brake setup
After doing brake jobs for years on a number of different makes/models, perhaps I was just naive, but I had never seen a drum parking brake built into a rear disk brake system. I had no parking brakes and had to tear into mine.
Just a bit of insight in case you have not seen it. Not too hard, just different.
Old Jan 10, 2005 | 07:31 AM
K2JJB's Avatar
K2JJB
I am pretty certain that the rotors on the 96 AWD are the same as the 97 AWD. In that case the fronts are easily removed (once you get the caliper mounting braket loose) and replaced. The rears are a little more difficult in that the disc, as pointed out by EXPL4X4, has a built in hub for the parking brake. Those are a little more diffucult to do (since I was not patient I had those done for me, but did the front's myself) as the hardware that is on the parking brake also has a tendency to rust up in there.
The bearings on these vehicles in the front are integral to the hub so just hope you don't need to do those as that gets expensive.
Old Jan 10, 2005 | 07:40 AM
2Mac's Avatar
2Mac
My 96 explorer 4WD was the first brake job I ever did and to be honest with you the backs were alot easier than the front! Maybe I got lucky?
The fronts were harder in that I couldn't get the caliper mounts to come off because the 2 bolts holding them on were so hard to get off that I stripped them and had to cut them off with a Zip cut grinding wheel.
With the backs you don't need to take the mount off, you just undo the calipers and pull the disk off. Like I said maybe I got lucky with that backs!...or it felt easier because of the problems I had with the front!
Good luck
