My 2000 PSD leaks out of the Fuel Separator valve when its cold (20-30 degrees) before I start it up. I've drained off the water several times since this behavior started. It'll stop leaking for a while & then start again.
Just as a followup, this was indeed the Fuel Separator valve. I replaced it & my leak stopped. It looks like there was some grit between the ball valve and the rubber washer. Also the washer was pretty hard compared to the new one.
I'm wondering if I could have gotten away with a pair of 30 cent washers instead of a $57.00 assembly.
