'04 Fog Lights Question
Old Jan 7, 2005 | 11:30 PM
GottaHaveIt's Avatar
GottaHaveIt
I have an '04 SuperCab and have had it about a month. It looks as though my fog lights and even my headlights are shining all uneven. I asked them at the dealership to take a look and correct if needed. They said that they were fine and thats the way the new ones all are. Well i dont believe that so i was wondering how i adjust the fog lights and/or headlights as i cant seem to find it in the manual and the dealerships dont want to help...anybody know??? Also, I am hearing a slight squeaking noise when i'm driving and hit bumps....is this something i should worry about or take in to the shop? How can i fix this on my own because it is kind of an annoying squeak?
I appreciate any help you guys can give to me.
Old Jan 8, 2005 | 12:44 AM
superfx4's Avatar
superfx4
Where is the squeak coming from? I have a squeak coming from the front of my dash where the security light is. It usually only squeaks when I hit a bump also. It sounds like a clip is broken or loose in the dash. I also had a very bad squeak coming from the pins that latch my tail gate. There is little plastic covers over the steel pins(I don't know why). It sounded like there was someone in my box with a chalkboard and a fork going crazy. The mechanic tightened the latches and spayed some wd-40 on them and no queak for now. But this is the 5th time that this was done. Hope this helps.
