94 F150 Highbeam switch
Old Jan 7, 2005 | 10:23 PM
clean79150's Avatar
clean79150
Maybe someone can help me out. 1994 F-150 XLT high beams won't stay on unless you hold the turnsignal lever with your hand. I don't know much about these newer trucks, and would appreciate any advise. Anybody else have this problem? Is it a tough fix?
Thanks in advance,
Ron
Old Jan 7, 2005 | 10:48 PM
MemOrex's Avatar
MemOrex
Are you holding it towards you? The highbeams turn on by pressing the lever away from you.
Old Jan 8, 2005 | 08:36 AM
clean79150's Avatar
clean79150
Thanks for the reply93green150.
The highbeams don't work when you push the lever forward. They won't work unless you pull back on the lever like your flashing your headlights. I don't know if that is a problem with the dimmer switch, or something else?
Old Jan 8, 2005 | 09:27 AM
tex94F250's Avatar
tex94F250
More than likely your multi-function switch. Easy to replace. About $50.00 @ Ford. If you don't have a Chilton's or Haynes, post and I am sure one of us will walk you through it. Replace mine in my '94 F250 in under 20 minutes.
Tex
Old Jan 8, 2005 | 09:42 AM
MEANBLUOVL's Avatar
MEANBLUOVL
Smile
have you pulled the cover to see if it is a brokken wire? good luck!!
Old Jan 8, 2005 | 11:03 AM
clean79150's Avatar
clean79150
Thanks for the replies, I haven't looked at it yet. Now I know where to start.
Old Jan 8, 2005 | 04:35 PM
88n94's Avatar
88n94
When the switch is held back it activates what is called a flash to pass feature. Does this intensify the low beam side of the headlight bulb or actually switch to bright? I actually don't know. If it intensifies the low beam side, it is possible that both bulbs are burned out on the high beam side.
Old Jan 8, 2005 | 04:48 PM
Popa Tim's Avatar
Popa Tim
The flash to pass actually activates the high beam headlights while leaving the low beams on also. This gives you all four elements active at once whereas switching to highbeams turns off the lowbeams.Popa Tim
ron sims
Oct 14, 2014 01:19 AM
uscrpick
1978 - 1996 Big Bronco
Jan 24, 2005 02:26 PM
toledoslim2
Sep 29, 2003 06:53 PM
arapco
Oct 21, 2000 07:30 PM
