FX4 Rear End Lowering
Old Jan 7, 2005 | 01:05 PM
BruceFX4's Avatar
BruceFX4
Does anyone know if the pinion angle needs to be changed when the blocks are removed from the rear axle on a 4x4? If, so any idea on how much of shim is needed?
Thanks
Old Jan 7, 2005 | 07:24 PM
industrialjunk's Avatar
industrialjunk
When I took out the block and added the drop shackle, my pinion only moved 1.1 degrees.Not much of a change to worry about.
Old Jan 8, 2005 | 05:52 PM
BruceFX4's Avatar
BruceFX4
Many thanks. I hoping it was less than 2.
