1978 - 1996 Big Bronco
'88 Bronco Ignition problems
Old Jan 7, 2005 | 10:58 AM
EinsteinMan's Avatar
EinsteinMan
Angry '88 Bronco Ignition problems
I have a '88 Bronco XLT with the 5.8L engine. It stopped starting suddenly the other day, as in I drove it to school, and when I came out to go home it would no longer start. I tried replacing the electrical ignition switch in the steering column, but that hasn't fixed the problem. I can hot-wire it with a wire from the battery to the solenoid with the switch in the "ON" position, and it starts that way, and then I can turn it off with the switch, so I know the switch is alright. Any other suggestions for what could be the problem, as I'm getting ready to sell the truck.
Thanks
Old Jan 7, 2005 | 11:52 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource! The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
We are pleased you have chosen, the best source of Fords…..there is!
See you on the boards
Old Jan 7, 2005 | 03:07 PM
jdmorg's Avatar
jdmorg
Einstein....check out this link...you may have already, right now, it's only two titles above yours
https://www.ford-trucks.com/forums/s...d.php?t=323557
it's by little rowe boat...same thing it sounds like, just with an '89. Good luck
