Another oil question.....duck!
Old Jan 7, 2005 | 08:54 AM
SBV45's Avatar
SBV45
Anyone ever use or have first hand experience with the Citgo Mystik JT-8 oil with the 6.0?
Old Jan 7, 2005 | 08:56 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
You just had to do it didn't ya
Old Jan 7, 2005 | 09:38 AM
huntercgr's Avatar
huntercgr
QUACK !!! Rebel rouser.
Sooo, is it less expensive? Or just something that's more readily available for you?
Old Jan 7, 2005 | 01:30 PM
SBV45's Avatar
SBV45
I thought I could get the 10W-30 but not so. I cannot find CI-4 in 10W-30 anywhere in Central Texas. I am told it is not necessary.
I will stick with the Rotella T synthetic 5W-40 through the winter months.
Old Jan 7, 2005 | 05:20 PM
RJB1's Avatar
RJB1
i ran the Mystic in my last 7.3, once. It was the only time I ever burnt oil so I never tried it in my 6.0. My .02
Bob
Old Jan 8, 2005 | 07:12 PM
cncfarmer's Avatar
cncfarmer
i checked on the Rotella T synthetic 5W-40 and it only has a CH-4 ratin and is not recomended for the 6.0
Old Jan 8, 2005 | 10:47 PM
huntercgr's Avatar
huntercgr
Beg your pardon cncfarmer but it is rated API C1-4.
http://www.shell-lubricants.com/prod...TSynthetic.pdf
Old Jan 8, 2005 | 11:23 PM
guydiver12's Avatar
guydiver12
cncfarmer was correct......the last time I looked at Rotella T syn, it was rated CH-4. I went to the Shell web site a month or so ago, and it had a rating of CH-4. I just went to the site again, and it has been changed to CI-4. They only did this recently. I have yet to see a container labeled CI-4 on the shelf anywhere I can find this oil around Shreveport, La. All of them say CH-4, so this is a new rating for this oil. I'm sure they have some more current labeled bottles in different parts of the country. I spent days looking at oil containers before I did my first oil change on my 03, and Rotella T was the first oil I looked at, just didn't have the rating back then.
Old Jan 9, 2005 | 10:01 AM
SBV45's Avatar
SBV45
cncfarmer, why do you say the Rotella T syn is not "recommended" for the 6.0. According to Ford owner manual diesel supplement, if it is API CI-4, CH-4 is acceptable if CI-4 is not available.
Old Jan 9, 2005 | 01:59 PM
f250meangreen's Avatar
f250meangreen
I was going to use Rottella T synth since the website said it was CI-4. That was last July and I have not found one in the stores yet rated anything other than CH-4. That is a long time for a change over that has not happened yet. I still look to see if the Rottella CI-4 is on the shelf when I buy Mobil truck/suv.
Old Jan 9, 2005 | 03:18 PM
mlb4966's Avatar
mlb4966
Just went outside to stoke the woodstove in the garage and grabbed a bottle of Rotella T 5W-40. Just got it a month ago. No CI-4 rating on this bottle but it does have the CH-5. Page 29 of my 6.0 manual says, If Ci-4 is not available, ch-4 is acceptable... SBV45 already stated this.
I have had no problems running with it so as long as it is acceptable via ford I'm not worry about it. Tried to find a "Born on date" but all I saw was 2004.
Old Jan 9, 2005 | 03:20 PM
mlb4966's Avatar
mlb4966
Ooops. Dont you hate it when your fingers are 1 keystroke off. CH-4 not CH-5
