460 overdrive trans
Old Jan 6, 2005 | 11:16 PM
JWILL460's Avatar
JWILL460
460 overdrive trans
Howdy. Looking for some info on maybe converting my 79 F150 460/c6/np205 to an overdrive trans. Can I still keep my 205 x-case? I am currently running 4:11 gears and would like to go to possibly 4:56 with an overdrive swap. Im can easily get ahold of a 4R100 or E4OD through work or one of our customers. Any suggestions are much appreciated.
thanks
JWILL...IOWA
Old Jan 7, 2005 | 12:20 AM
Craigwell's Avatar
Craigwell
someone was talking about the bolt on units that are installed
behind the transmission in here once, check the history maybe.
the only thing i cam think of is if you went to a divorced
tcase setup: 460>C6>OD unit>NP205 the length of the OD unit might
not allow you to use an intermediate shaft between the OD
and the tcase tho.. *shrug* this might be a cheap option,
really, if you didnt mind a little adaptation and hunting
around for parts..
if that kind of cloud talk doesnt suit yer fancy, then get
out your wallet and buy a beefed up AOD 4x4 model tranny, bolt
your NP205 to it, and find an adapter plate kit so it
fits the 460.
My truck: 300 six>AOD>NP205 (divorced). Mine has the 4.10
gearing and works quite well. the overdrive is .67 with a
lockup tourque convertor. I find the highway limit is only
50mph or less in third gear, (1:1, no lockup tc) but with
overdrive, I can run 75mph without the six screaming at me
stop beatin the valvetrain.. heheh
i dont often drive 75mph in my 5,500 lb 4x4, but its fun
knowing i can.. :-)
