Torque Converter Shudder
Old Feb 3, 2005 | 03:03 PM
cbreit's Avatar
cbreit
i think that is part of my problem also think i may be loosing vacuum to just one front hub at times
Old Feb 9, 2005 | 11:46 PM
Missouri Mule's Avatar
Missouri Mule
I've had this problem in 2 or 3 Ford products and each time a complete fluid change corrected it. I was once told by a Ford tech I needed a new torque converter. I changed the fluid and I drove it another 30,000 miles without any further problems. That would be the first thing I would do.
Old Feb 10, 2005 | 01:47 AM
yardbird's Avatar
yardbird
I have posted earlier in this thread about the T/C shudder in my 95 t-bird. It has had the shudder since I bought the car. I put in an 18,000 lb. trans. cooler and had the fluid flushed and replaced with mercon V. I also added some Lubeguard transmission treatment.
These things only stopped the shudder for a short time.
Since the last post I bought a 2 oz. tube of Dr. Trannys Instant Shudder Fixx and poured it in. Within 20 minutes all of the shudder was gone. The shifts are firm, and T/C lockup is immediate. The hill below my house that I have always had shudder on is now smooth as glass.
This is a friction modifier, such as mercon V is a friction modified version of mercon.
I don't know how long it will work, but it is a joy to drive my car again. At $7.99 it sure beats the price of a new T/C.
There are too many of these Fords shuddering for all of them to have bad torque converters, so this might just be what is needed to help them along.
Here is the web site. Several other people I have talked to have used this over longer periods of time with nothing but good results.
http://www.lubegard.com/automotive/t...dder_fixx.html
Old Feb 10, 2005 | 09:59 AM
Missouri Mule
This is good information. Does anyone know why this is happening? What is going on exactly? Replacing torque converters is about a $700 fix.
Old Feb 12, 2005 | 11:52 PM
dybeepvw's Avatar
dybeepvw
Hey yardbird, where do you buy this Dr. Tranny shudder fixx. My 87 f150 with 4.9L and C-6 automatic is doing it in high gear between 30 and 45mph. Thanks
Old Feb 13, 2005 | 12:32 AM
yardbird's Avatar
yardbird
I got mine at the local Carquest dealer. You can do a search on google and mail order it. Just be sure to put in the complete name before you search. If you just enter "tranny shudder" you will come up with some strange sites.
I posted a link to the mfg, International Lubricants, in my last post.
Mine seems to shift better each time I drive it.
Old Sep 20, 2010 | 08:08 AM
Larry32144's Avatar
Larry32144
I have a 2010 F150 Lariate screw with 3500 miles. I did not test drive the truck before purchasing or would not have purchased. I've had this problem since Day 1. Been to dealers nine times for service and problem still exists. Ford Customer Service says that all F150s do this and will not replace the torque converterr.
Old Sep 20, 2010 | 09:05 AM
racerock's Avatar
racerock
Not sure if this helps, but my 03 Navigator was showing torque converter shutter conditions...
This summer, replaced the coils - as I started to think that maybe it was a coil (or two) not firing...
Fixed it!
Old Jun 25, 2012 | 11:49 AM
berry1234's Avatar
berry1234
Fixed it!
Did you replace all of them?
Old Oct 16, 2013 | 08:31 PM
HogTied's Avatar
HogTied
Originally Posted by ron_fordtruck
My FX4 has a shudder when it downshifts out of OD going up a hill. It feels like I am running over small speed bumps on the right rear of the truck. The dealer flashed my computer to no avail. Hope you guy figure it out.
The EXACT same thing is happening to mine. Just started this week.
Old Oct 20, 2013 | 05:23 AM
ford-lover's Avatar
ford-lover
I have the 07 XLT 5.4 2X4 with 90K km and started to have the same TC shudder problem last week. After reading the post, I am going to change the XMT fluid and filter and hope for the best.
One question: If replacing the fluid can "fix" this problem, why not add a drain plug in the pan and change the fluid once a year like doing an oil change for the motor. This way the modified friction will never "wear" out because of the new MerconV oil.
Old Oct 23, 2013 | 08:12 AM
cyclone3565's Avatar
cyclone3565
Drive it in "3" not D, which prevents the TQ from engaging. If it does not happen again, it is the Torque converter.
Old Oct 23, 2013 | 12:04 PM
  #28
HogTied's Avatar
HogTied
This is a false statement. If driven in 3rd it will actually lock the torque converter in 3rd after drivetrain load levels out.
Old Oct 27, 2013 | 01:17 AM
  #29
ford-lover's Avatar
ford-lover
Updates ....
Talked to a trusted xmt tech and was told that the complete fluid flush may fix the shudder problem if the TC is not damaged. Replacing the TC with a heavy duty unit is the ultimate fix and cost around $800. No sure which way I will go but tend to change the fluid and filter first and hope for the best.
Old Oct 30, 2013 | 01:02 AM
  #30
wolfy's Avatar
wolfy
Are you 100% sure it's not a miss fire? Mine did this right when the TC locked up about 40 mph. It was the spark plugs.
