1978 - 1996 Big Bronco
96 bronco
Old Jan 5, 2005 | 10:13 PM
bigdogfool's Avatar
bigdogfool
96 bronco
I have a 96 bronco. The speedometer went out and soon after when I get to about 35 mph it jerks and hesitates. I heard it is the speedo sensor on the rear axle, does this sound right? and if so is it easy to replace?
Old Jan 5, 2005 | 10:22 PM
greystreak92's Avatar
greystreak92
Yes, the VSS (Vehicle Speed Sensor) is mounted in the top of the rear differential housing. It is held in with a single bolt. Often cleaning the sensor is enough to restore proper operation however, with the PSOM (Programmable Speedometer/Odometer Module) not functioning at all, check the wiring to the sensor and if there is no problem there or at the connection, its probably time to replace it.
