help with odd noise
it seems to be draining some power from the motor, as well as making the pedals vibrate. it only does it at idle, and mostly when it's cold.
if possible, i'd like to remove the smog pump assy anyway, as arkansas has no inspection at all, let alone emissions tests. for reference, it's a 93 f150, EFI, M4OD. replaced the exhaust from the cat back with a high-flow glass pack muffler. other than that, it's stock.
