shift points
Old Jan 4, 2005 | 08:36 PM
walkpast's Avatar
walkpast
shift points
Its been about a year since I bought my 84f150. Its had a few mods:larger holly 2barrle cab, both convertors cut off, larger 3inch pipe with a better flowing muffler,and holly breather with foam filter. So i got the power up where I want it. Now it seems my trany [overdrive auto] just dont seem to shift in the right spots to make good use of it.Yes I like milage and convenace of the trany, but is there a way to give it a better powerband.
Old Jan 5, 2005 | 07:20 AM
ronclark's Avatar
ronclark
Transgo makes a shift kit that allows you to adjust the shift points. Not a real easy install for someone who doesn't work on auto trans becaause it requires some drilling in the valve body area but they doinclude an instruction video.
Old Jan 5, 2005 | 09:26 PM
walkpast's Avatar
walkpast
Ive done alittle tans work in the past, so I might give it a try.Has anyone put one of these kits in? If so how hard is the job for a nonpro.And what is the price range of the kit.
Old Jan 6, 2005 | 08:11 AM
ronclark's Avatar
ronclark
Transgo kits for an AOD cost between $70 and $120 depending on where you buy.
The kits can be installed by a non pro but it is not easy and not without danger to the trans. Some non pros have installed the kit and are happy with the result and others have installed the kit and their trans wouldn't shift anymore and they ended up at the trans shop. With these kits you are nor only enlarging holes in the seperator plate but also drilling new fluid passages to reroute the fluid to elliminate the clutchpack overlap between gears. The AOD doesn't release the clutchpack for one gear until the next clutchpack is engaging causing overlap between shifts thus stopping the harsh shifts from older trans like the c4 c6 fmx.
Old Jan 6, 2005 | 05:04 PM
walkpast's Avatar
walkpast
Hey thanks for the info.I may look into how much a shop would charge to put one in.
85rangerdanger
1983 - 2012 Ranger & B-Series
Jul 7, 2011 09:20 PM
Glockem45
Sep 1, 2009 09:08 AM
Glockem45
20
Jun 29, 2009 07:17 PM
cody -mac
36
Mar 2, 2008 09:44 AM
Mr Personality
Apr 20, 2003 10:35 PM
