Sponsored by: Kumho
Wheel offset on 4x2 vs 4x4 Same? different?
Old Jan 4, 2005 | 05:21 PM
msu-dawg's Avatar
msu-dawg
Question Wheel offset on 4x2 vs 4x4 Same? different?
First, I tried finding info on this through search in both this forum as well as the 97-03 trucks forum with no luck.
Secondly, I know what offset means, I know what backspacing means, and I've seen a reference to "inset" which I would presume to be negative offset.
Now my question- on f-150's, particularly in the 97-03 range, do the wheels that come on 2wd trucks have the same offset as those on 4wd trucks? I'm aware that certain OTHER vehicles (read chevy s-trucks) were different for each.
For instance, I'm looking to swap to a 17" OEM wheel from my 16's and I'm looking at the 5 spoke chrome rim that I've seen only on 2wd lariats. It's actually a steel wheel with a prermanently installed chrome overlay of some sort. And, I've been looking at the 5 spoke with the exposed lugnuts and black centers that I've seen only on 4x4 trucks. I've seen one of those 4x4 wheels up close that had "14mm offset" cast into the back of the rim (meaning the mounting surface sits closer to the front of the wheel). However, I thought I had seen reference to 14mm INSET on some 2wd rims. I could just pull one of mine off and measure it but I was hoping someone here could save me that trouble.
Old Jan 5, 2005 | 04:19 PM
gatesj's Avatar
gatesj
Not sure about those newer trucks but I am certain that on 80-96 trucks they are no different. Someone will come along soon...
ToasterVan
Transit Connect
Jan 29, 2017 07:24 AM
LEDman
Nov 22, 2016 11:29 AM
ThoobHertz
2009 - 2014 F150
Jun 19, 2016 10:32 AM
Principle
Aug 14, 2013 11:45 PM
Fallguy2004
Dec 19, 2010 09:58 AM
