Can a MAP sensor be adjusted?
Old Jan 4, 2005 | 01:40 PM
quehele's Avatar
quehele
1986 Ford Truck - 2wd - 5.0L - EFI - aftermarket cam.
The engine goes rich at idle. Apparently the MAP sensor reads the low vacuum and assumes that the engine is excellerating.
Is there a fix? Can the MAP be adjusted?
Thanks for the help.
Mike
