94 F250 Automatic Transmission problem
Old Jan 4, 2005 | 12:36 PM
emon's Avatar
emon
Well here is the problem, my truck only goes forward every gear range goes forward neutral, reverse, etc. there isn't a check engine light on. before this happend I had to rev up the engine really high like 2500 before the truck would move. I checked the trans. fluid and it was ok but I don't know much about auto matic transmissions so I don't have a clue on what could be the problem. If there were even things that you guys could point out to me to check out that would be great also. thanks
Evan
