Front Suspension Lift
Old Jan 4, 2005 | 11:11 AM
MikeGV's Avatar
MikeGV
Question Front Suspension Lift
I have a 2wd 78' Supercab with a factory 460 & SuperCab.
1. I want to run 31x10.50 tires on 9" wide 15" rims. I am concerned that they will rub the front fenders, as there is only 3" from the top of my current 235/75R15s to the wheel well.
2. I am trying to determine whether the front springs are sagging. How many inches is a stock front spindle to center of wheel well (unless there is a better way to measure). Does anyone have a non sagging 460 supercab f150 they would be willing to measure?
3. If the front springs are not sagging, does a 2" spring leveling kit generally require the ibeams to be bent to get the camber back to spec or is 2" not enough to affect the suspension symmetry? Unless there is a leveling kit that comes with something else to put camber back. I have seen some of these level kits but none of them say anything about alignment changes on our trucks.
4. Has anyone ever used a leveling kit on a SuperCab with a 460? All the leveling kits I've seen seem to be universal to all motors.
Thanks!
Old Jan 4, 2005 | 09:47 PM
f250rangerexplorer's Avatar
f250rangerexplorer
Here is a metric to american size chart.
215/75R 15 = 28 X 8.50 X 15
215/85R 15 = 29 X 8.50 X 15
225/75R 15 = 28 X 9 X 15
235/75R 15 = 29 X 9 X 15
325/60R 15 = 31 X 12.50 X 15
You should be able to run a 31" with no problem. If you got 29" tires thats only 14.5" from the center of the hub to the outer edge of the tire.measure from the center of the hub to the fender in a Vertical line and then minus 2" or so then double it then you got your max tire diameter. i got 31's on my 4x4 lowboy and i got enough room for almost 35's but on a 2wd i would say 31's should fit easy.
-Aaron
Old Jan 24, 2005 | 11:22 PM
MikeGV's Avatar
MikeGV
2wd Leveling Front Lift
Has anyone installed a leveling lift kit on a 2wd truck?
I am having trouble finding one.
Did any of the 4wd trucks from this generation use coil springs? Are they the same coils as the 2wd?
Thanks!
Old Jan 25, 2005 | 12:10 AM
f250rangerexplorer
the f-100 and f-150 used coils but the bigger ones used leafs.
Old Jan 30, 2005 | 02:48 PM
doc_f250's Avatar
doc_f250
You can find spacers for the front springs, but the i-beam alignment becomes the problem. $700 buys you a 3" Autofab lift....$1350 for the 5".
Doc
