Oil & Lubrication
pressure relief??
Old Jan 4, 2005 | 09:27 AM
smoke n tires's Avatar
smoke n tires
pressure relief??
i was reading a thread about a stuck pressure relief valve. i might have that problem. when cold i have 70 psi (true reader guage) at idle as it warms i drop to near 0 psi. when i rev the motor it comes up to about 20-25 psi at 2500 rpm give or take a few. the motor is a 78 460 with a 120000 miles. any thoughts???
Old Jan 4, 2005 | 11:48 AM
rusty70f100's Avatar
rusty70f100
It sounds like bearings. I'm not familiar with the oiling system on the 385 series, I'm an FE enthusiast myself. But the usual suspects are cam, main, or rod bearings. I'd replace the main and rod bearings first to see if that fixes it, since the cam bearings are much harder to get to.
Old Jan 5, 2005 | 03:18 PM
ford390gashog's Avatar
ford390gashog
what weight oil are you using i would use 15w40 rotella oil that should give you some oil pressure and make sure you use a good oil filter
