Removing Bumper Bolts
Old Jan 3, 2005 | 08:58 PM
BoomerPower's Avatar
BoomerPower
Question Removing Bumper Bolts
I'm swapping a chrome bumper onto my 1980 F350 and I'd like to know how I can remove the chrome bolts without damaging them because I've had trouble before taking them off because you can't get a wrech on the end of them. If anyone has any ideas it'd help. Thanks.
Old Jan 4, 2005 | 12:00 AM
85f150-Prerunner's Avatar
85f150-Prerunner
Im not familiar with the location since im new to ford but try soaking them for a bit with penetrating fluid. Then use heat and if you can get a impact socket on them that may work.
Old Jan 4, 2005 | 12:31 AM
Birdhunter1's Avatar
Birdhunter1
Pretty much what 85 said is all you can do. The bumper bolts have a square shank that fits in the bumper and if it rounds at all your best bet is to grind the heads off and try to bust them out with a chisel.
Old Jan 4, 2005 | 12:36 AM
85f150-Prerunner
I am planning on making a set of custom bumper bolts as well as other bolts that start with a regular heavy duty bolt. I want to cut the head off and weld on a wrench so when you look at it all you see is a wrench where the bumper bolts are. Just think it would look cool since im a fleet maintence tech for a trucking company
74 F350 SCS
Dec 3, 2011 05:16 PM
mcjones44us
6.4L Power Stroke Diesel
Apr 16, 2009 04:33 PM
Vijay
Apr 8, 2008 01:22 PM
phoneman71
Appearance & Dress-Up
Feb 1, 2005 01:52 AM
Blaine
Apr 26, 2002 08:55 PM
