Sponsored by: Real Truck
Whats those wires?
Old Jan 3, 2005 | 06:18 PM
engine28's Avatar
engine28
Thumbs up Whats those wires?
Got my new 04 F250 PSD home and was checking things out under the hood and found 4 exposed wires(white,red,blue and black) pulled from the plastic sheath not connected to anything. They're between the power steering reservoir and the firewall on the drivers side, and are actually in the same sheath as the hood light wiring. Was curious as to their purpose. thanks
Old Jan 3, 2005 | 06:50 PM
mrc59's Avatar
mrc59
I think this is for your trailer brake controller.
Old Jan 3, 2005 | 07:00 PM
1olddog2's Avatar
1olddog2
no, there customer access wires. on the other side of firewall u will see the the other matching set of wires by the steering colum
Old Jan 3, 2005 | 07:48 PM
Tuggingafiver's Avatar
Tuggingafiver
sure glad someone knows what they are,,
dealer was at a loss on the new 05,, of course he did not even know where the aux switch wires terminated so guess he sure would not know about those four wires,,
do appreciate,,
Old Jan 3, 2005 | 11:52 PM
Dieselman929's Avatar
Dieselman929
Customer access for what? I'm thinking maybe I didn't have to pop holes on my rubber grommets but instead use those "customer access wires" ??
Old Jan 4, 2005 | 05:45 AM
bgrover's Avatar
bgrover
Dieselman929, that is exactly what they are for. The wires are there so that you can hookup anything you need without having to pull your own wires through the firewall.
I first found out about the wires here (there are some other threads on them). If memory serves me correct when I went back and re-read my owners manual there is a short 1 or 2 sentence paragraph about them burried in the manual someplace.
Old Jan 4, 2005 | 08:54 AM
Dieselman929
Thanks. Guess a mechanic(TECH) made it onto the engineering team, EH?
Old Jan 4, 2005 | 07:29 PM
1olddog2's Avatar
1olddog2
yeah some one did good. hey fiver u find those aux leads yet ? u have to drop the fuse box, 4 10mm bolts u should see them mark for each switches
Old Jan 4, 2005 | 08:05 PM
f2fitty's Avatar
f2fitty
I just installed a fog light kit from ford and they refer to the four wires as "pass through wires".
