Sponsored by: Real Truck
Scale # F350
Old Jan 3, 2005 | 05:27 PM
Rogue427's Avatar
Rogue427
Scale # F350
Raan my truck over the scale yesterday. Front was 5900#. Back 2730#. My truck is a 05 F350 CC LB SRW Diesel. Full tank of fuel and 9'2" Boss V Plow on. And don't forget my 185#. Tim R.
Old Jan 3, 2005 | 06:13 PM
beemr's Avatar
beemr
I did mine on Friday. 04 F350 CC LB 4x4 6.0 SRW. With full tank of fuel, me at 175, truck weighed in at 7660 lbs.
Old Jan 3, 2005 | 06:28 PM
Deaver's Avatar
Deaver
Did mine on 12/29
03 F250 (7.3) PSD ECab, Long Bed, Full Tank, 180 Lbs Driver
Front - 4640 Lbs
Rear - 3120 Lbs
Total - 7760
Old Jan 3, 2005 | 07:21 PM
wvabeer's Avatar
wvabeer
mine was 6500 lb don't remember how much gas was in there
Old Jan 3, 2005 | 07:41 PM
04superduty's Avatar
04superduty
mine is a 04 350, PSD, SB, EC with alot of balast, and 150 lbs of salt. with a 9'2" v blade. front was 5500, rear was 4000.
Old Jan 3, 2005 | 07:46 PM
utahtom's Avatar
utahtom
I've weighed my truck (03 6.0 SRW CC SB) on many occasions and come to the conclusion that it weighs 7,100 lbs dry... 7,300 lbs w/full tank of fuel. So Lets check beemr's numbers: Add 125 lbs for the longbed and another 60 lbs for additional fuel + 175 (for beemr) and you get 7,660 lbs. Amazing!!!
I think I will list beemr as a character witness for me the next time someone posts that the 6.0 CC's don't weigh over 7,000 lbs
Old Jan 3, 2005 | 08:53 PM
SoCalDesertRider's Avatar
SoCalDesertRider
My F350 is a little older ('92). It usually weighs 6500 lbs at the dump with an empty bed. It's a CrewCab 4x4 SRW longbed 351. If mine had the diesel, I would expect it weight just over 7000 lbs, which would allow me a whopping 2200 lbs of payload (9200 GVWR).
Old Jan 3, 2005 | 09:01 PM
SMiller's Avatar
SMiller
I'm at 6400lbs empty, loaded a little rock today was at 10,000lbs loaded. I'm pretty light compared to you guys.
Old Jan 3, 2005 | 09:38 PM
Fire Rooster's Avatar
Fire Rooster
Well looking at your sig I think the reason you are so much lighter is self explanitory.
5.4L motor, regular cab, and not sure if it was a 4x4 or not. But I'm guessing that the shear lack of metal would account for your weight.
Old Jan 4, 2005 | 03:09 PM
SMiller's Avatar
SMiller
Oh yah, I figured the same, no diesel and the lightest configuration minus the 4x4... Some of you diesel guys are really heavy
Old Jan 4, 2005 | 03:42 PM
SLE's Avatar
SLE
03 F250 V10 CC Short box + full tank of fuel + me (165lbs) + Tow rope, reciever hitch ect. (+-100lbs) = 7020lbs on the DOT scale for the comercial trucks.
Front Axle = 4030lbs ----- Back Axle= 2990lbs
Seemed a bit heavy since it's not a long box, not a diesel, and not a 1 Ton.
Old Jan 4, 2005 | 09:00 PM
Rogue427's Avatar
Rogue427
Heavy
Are you hinting that diesel owners are overweight? LOL Tim R.
Old Jan 4, 2005 | 09:30 PM
farmb0y's Avatar
farmb0y
I don't feel too bad now, I thought I was "overweight" when I was weighing in at 7600#, SC SB 4x4 PSD, but some of you guys are even heavier than me. I spose those 9' plows don't help much either.
Old Jan 4, 2005 | 10:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
86 7.3 turbo 4x4 regular cab weighs 8060 full of fuel.
Add 200 pounds of me and a little rock, pull off the scales at 16,000.
Old Jan 5, 2005 | 08:57 AM
SMiller's Avatar
SMiller
Ah that would be you and a little rock in a trailer. Don't think your getting 8,000lbs of rock in the bed.... Had 6,000lbs in the bed of my SD the other day and it looked just about maxed out.
