Replacing 240 I6 w/ FE - what changes?
Old Jan 3, 2005 | 10:00 AM
truckjunky87's Avatar
truckjunky87
I have a 240 I6 with a NP435 and a divorced t/case in a '69 F250 Highboy. I'm dropping in a FE, 352 or 390, and now want to keep the NP435 behind it. From what I've been told the engine mounts locations will work fine but does the rear face of the block line up the same? If not this will affect everything downstream, ie crossmembers. I also need to find a bellhousing. Anything specific about the FE-to-NP435 bellhousing or are all FE bellhousings the same?
Old Jan 3, 2005 | 12:14 PM
michaelbrainardatwor's Avatar
The biggest change might be the thickness of your wallet Sorry, can't be of more help, but I had to!!!
Old Jan 3, 2005 | 11:02 PM
Fomoko1's Avatar
Fomoko1
If you get the proper housing for the motor/transmission every thing will line up. There will be a difference in the exhaust, rad and fuel lines ect. but this is minor and makes a nice swap. If you can try to pick up a parts truck as it will be alot easier to get all the small /big parts and save hunting for all the odds and ends you will need. It can be a newer truck up to a 1976 as most of the mechanical parts interchange between this years. These older Ford trucks were simple to work on and to swap components on.
redneckcustoms13
Ford vs The Competition
Dec 26, 2014 07:51 PM
redneckcustoms13
Dec 25, 2014 08:19 PM
redneckcustoms13
Dec 24, 2014 07:03 PM
beater123
Mar 16, 2011 06:03 PM
dirty_red_lobster
Dec 30, 2010 06:39 PM
