Sponsored by: Real Truck
Engine "Growl"
Old Jan 3, 2005 | 08:43 AM
wilkie67's Avatar
wilkie67
Question Engine "Growl"
Hi All. We just purchase a F-250 4x4 super-duty truck and it has this “low growl” when the RPMs drop after shifting into gear at about 45-55 MPH. It only does this when the engine is warm. Any Ideas?? Any help would be appreciated. The mechanics at the dealership seem to be confused. Thanks
lc
Old Jan 3, 2005 | 09:02 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
MY 2002 has done that since new. I have just assumed it was the converter locking up.
Old Jan 3, 2005 | 01:50 PM
wilkie67's Avatar
wilkie67
Interesting. Did they ever fix it. Has it caused any problems if you didn't??
Old Jan 3, 2005 | 01:53 PM
pops_91710's Avatar
pops_91710
oops. I mes sed this up see below
Old Jan 3, 2005 | 01:55 PM
pops_91710's Avatar
pops_91710
Is it a V-10 or what? What gear is it in when it does this? What is a low growl? Low in frequency or low in volume?
Mine does this and so does my V-10 van. It goes away as speeds increase. Only does it in top gear (O/D)
Old Jan 3, 2005 | 01:56 PM
wilkie67's Avatar
wilkie67
Cokeman. Just spoke with the dealership. They finally figured out what it was right after I read your response. Thank you very much. You were right. Have a great one!!
lc
Old Jan 3, 2005 | 02:05 PM
Bootskillet's Avatar
Bootskillet
So is this a bad thing? I have the same thing going on in my 2002 F250 when it shifts at 45 - 50 mph. I think it is going into 3 or over drive. I had posted the same question on transmission thread, got no response. So thanks for your help.
Old Jan 3, 2005 | 04:29 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
lc
Welcome to the only family Ford Truck site, on the net. As you can see.... The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
See you on the boards!
Old Jan 3, 2005 | 04:36 PM
1wheel's Avatar
1wheel
Wilke67,
What was it that the dealer found? Did it get corrected?
Old Jan 4, 2005 | 06:33 AM
wilkie67's Avatar
wilkie67
Thumbs up
It turns out that it's the Torc Converter. It's being replaced. Fortunatly this happened within the first 30 days of ownership and the dealerhip is taking care of it.
lc
Old Jan 4, 2005 | 07:03 AM
wilkie67's Avatar
wilkie67
It's a V8 and it's low frequency and usually does it between 45-55 MPH when the RPMs wind down after shifting into gear.
lc
Old Jan 4, 2005 | 09:14 AM
cokeman's Avatar
cokeman
I haven't done anything to mine. Seems like normal operation of a locking TC to me. Let us know how it goes.
Old Jan 8, 2005 | 09:55 AM
wilkie67's Avatar
wilkie67
Thumbs up Engine "Growl" solved!!
Got our truck back last night. The Torque Converter was on its way out The curious thing is, I've only known that to happen from extreme towing or excessive heat on the trans. They replaced it and the growl from the trans hump is gone. If you have a superduty and feel a low frequency hum or growl after you shift into passing gear and your RPM'S drop, then I suggest having it checked. Beware of the common answer of "Trans flushing" It will make it go away only temporarily. Kudo's go out to cokeman for the suggestion. One last thought, below 100,000 miles if you have a slight engine shudder at idle it is not the plugs, but possibly a coil getting ready to give out (it happen to us). Each plug has its own coil mounted on top since eace cylinder has it's own coil, the truck will continue to run, even though it has a shudder. Thanks
Old Jan 10, 2005 | 09:05 AM
cokeman's Avatar
cokeman
How much did they charge you to replace it?
Old Jan 10, 2005 | 09:49 AM
krewat's Avatar
krewat
Yup, that sounds like the TC lockup clutch slipping.
Used to happen very often on the 4R70W trannies, but using Mercon V ATF made it go away in both my '96 t-bird and '97 cougar 4.6L's...
For the 4R100 (E40D?), I've never heard of that as a pervasive problem. Also, you can't use Mercon V in the tranny either.
My '01 doesn't do it - I would notice it, and be freaked because they aren't supposed to do that.
The major reason for clutch glazing is fluid temp and load, but I'm sure it could happen at any time... a fluid change is worth the trouble.
Sounds like you'll all need torque converters sooner or later
