Finally today I started my motor for the first time in about 5 months. I had to pull it out to put the plugs in properly, they were backwards. It started after only a few cranks. This thing is really powerful. It has exceeded my expectaions and then some. Its really hard to control the throttle, everytime I step on the gas it peels out and accerlates really hard. This thing rocks! All of my hard work has finally paid off and I can enjoy it. My oil pressure is hovering around 30 psi but I think my gauge is off and I have more then that. Also there are no oil leaks. I do have a slight problem though. I am running a Holley 600cfm 4bbl Vacum Secondary carb. I know nothing about carbs at all. Whenever I accerlate hard, it stumbles/hesiates, then revs all the way to redline. I plugged all of the vacum ports on the carb. How do the secondarys work on the holleys? Do the back 2 barrels open from inteneral vacum or is there an exterior vacum line on the carb do open up the secondarys? I know its a dumb question but I really know nothing on carbs at all.
You cant beat the old FE's, I am not kidding this thing is extremly powerful, and its not even broken in yet!
The secondary diaphram picks up vacuum from a port in the primary throttle bore. The air going by the port creates a vacuum, which pulls the diaphram up, overcoming the pressure of the spring, and thereby opening the secondary throttle bores. Therefore, the secondarys open as a result of airflow, not manifold vacuum like their name may imply.
That doesn't sound like your problem though. I think its the accelerator pump. Take the air cleaner off and, with the engine off, manually actuate the throttle while looking down the carb. Have the choke fully open obviously. You should see a small jet of fuel squirting into the primary (not secondary) throttle bores as you open the throttle.
Refresh us on the specifics of your build again, if you would.
The accerlator pump is fine I took a look at it and it it is squirting fuel niciley. This is a newly rebuilt carb, so Im hoping everything in the carb will be in good condition. Also, I am at about 6,000 ft, what jet size should I be running? The dude that sold me the carb said it had #66 jets in it, is this the right size jet for this elevation? I am wondering if maybe my jets need to be change to solve the stumbling problem.
I dont think its the jets. If they were too lean it would ping at WOT. Now I'm thinking its too flimsey of a vacuum secondary spring. What this does is allow the secondaries to open too soon, creating a lean condition since the secondaries have no accelerator pump. Basically, you need to change (or have changed) the secondary spring. Any good auto parts store or speed shop will have a spring set. When I was running the Holley 600 vacuum secondary on my 360 I always used the purple spring. I tried the yellow one and it seemed to bog a little before it took off. They should have a chart on the back of the package as to what springs are applicable for what type of vehicle.
When you say that you accelerate hard, do you mean from idle or from a cruise mode? It could still be in the accelerator pump and squirter area, or the secondary springs as Rusty suggests. It would not be uncommon to have to little of a shot of fuel from the pump and squirters. There is also a pump cam assortment Holley sells to change when the pump shoots it's load. You can even get different squirters, of if you have a wire drill set you could open up the ones you have. I would start with the secondary springs, then the pump cam if that doesn't work, then either enlarge the squirters of even go to a 50cc pump if it will fit your model of carb.
Thanks for the response rusty and tastyklair, Im thinking that it is a weak spring like rusty suggests. I tried everything today to get the flat spot out but no matter how much tuning I did that darn hesiatation was still there. My other theroy is the accerlator pump is clogged with some dirt or something. I am contacting the dude that rebuild the carb tommorow to ask him about it. This flatspot, or heasitation comes on very quickly, after the flatspot though it screams all the way to redline, I have not been able to floor it yet, just too much wheelspin and loss of control. When I get it registerd and back on the road ill be able to see what its really got. It has much more power then I antictaped, its very addictive.
You also need to make sure there is NO clearance at idle between the accelerator pump cam and the lever on the bottom of the acc. pump diaphragm assembly. It might not be squirting at the right time. I don't think it would be clogged or you would have a very poor pump shot.
And also If when you had problems with it before and it back fired thru the carb..you might have a blown out power Valve in the metering block?? And double check your timing..and Like Putt said you want the Pump arm touching the The pump..but with NO pressure being on it.... Good Luck!! I know its been a long time waiting!!
Thanks for the help guys. I contacted the carb builder and he told me to try some stuff. I adjusted the little nut that controls the accerlator pump thing. It solved it. This thing is running perfect now and hauls ***! What a blast! All that work, time and money has paid off, I have a powerful daily driver that doseant leak anything, doseant tick, and doseant smoke, and I can keep up with the best of em. Next Goal: Pay off the loan for this thing, I owe my parents about $300. Im gonna get a part time job so I can still go to school and work at the same time.
Thanks for the help this is the biggest acomplishement of my life.
