98 - EB rough idle
Old Jan 2, 2005 | 01:46 PM
richjesus1's Avatar
richjesus1
98 - EB rough idle
i have a 98 eddie bauer expo ,i changed the spark plugs,pcv valve but im still getting rough ride ,my check engine light came on,the engine is very shaky,i checked trouble codes,i came out with po306 cylinder no.6 misfire detected.any advice on what the problem might be would be greatly appreciated.
Old Jan 2, 2005 | 02:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 2, 2005 | 03:10 PM
ohioclint's Avatar
ohioclint
Spark plug or coil for #6 cylinder is where I would start, just hope I don't have to!
Clint
99 Expedition EB 5.4 4WD.....
Old Jan 3, 2005 | 01:20 AM
richjesus1's Avatar
richjesus1
thanks ill do that
Old Jan 3, 2005 | 03:28 AM
Monsta's Avatar
Monsta
Sit. Stay.
richjesus1,
Tim welcomed you but let me do so also.
Welcome to FTE! I know you can get any of your questions about the Expedition answered here. We've got an incredible group of users here, so don't hesitate to ask!
Hope you keep postin'!
Now...on to your question and my .02
Since you just changed the plugs why don't you make sure the COP is fully seated and the wire isn't loose or frayed. The COP may be cracked, too.
They're fairly cheap. You can always buy one and swap it out to see if it eliminates the CE light & rough running.
Old Jan 3, 2005 | 12:30 PM
PaulC's Avatar
PaulC
BTW, which engine? The 4.6 was standard on the EB for a few years. 1997-1999 4.6 engines are not COP.
Old Jan 3, 2005 | 03:04 PM
richjesus1's Avatar
richjesus1
its a 5.4 engine what do u mean by cop.
Old Jan 3, 2005 | 04:28 PM
78Explorer's Avatar
78Explorer
cop = "coil on plug"
Old Jan 3, 2005 | 05:32 PM
richjesus1's Avatar
richjesus1
thanks for the help
Old Jan 4, 2005 | 04:19 PM
expydog10's Avatar
expydog10
Interesting.. I had the same symptoms yesterday and changed fuel filter, cleaned MAF and throttle body to no avail. Brought to dealer and it's the Coil pack and #2 cylinder plug...$350.00
Old Jan 4, 2005 | 06:02 PM
jbdecke1's Avatar
jbdecke1
I would replace the #6 coil (this is the second one back from the front on the drivers side), luckily the #6 is one of the easiest and should only take about 10 minutes to swap out. The coils are about $60 at any auto parts store. I would try to fix it yourself as dealers seem to be real proud of their work when it comes to replacing coils.
