thermostat query
Old Jan 2, 2005 | 12:48 PM
rangefinder93's Avatar
rangefinder93
thermostat query
Hey guys,
I have a thermostat problem with my ranger, and the simple job of replacing it, is not as simple as it should be. I have a 93 ranger 4x4 3.0, and my problem is this; one of the two mounting bolts is directly under a super stiff wire loom, which is under an injector line, which are both (the loom and injector line) in front of the intake manifold. What's up? And what should I do, or is this a job I should let somebody in a heated garage do for me??????? Thanks, happy holidays.
>Mike
Old Jan 2, 2005 | 12:53 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 2, 2005 | 07:09 PM
Peter94's Avatar
Peter94
well, i did mine 2 times, and i did it outside (summertime, warm) with the help of 2 extensions, a knuckle joint, and some profanity. the second time went 100x faster. But its possible, i have the same truck as yours just a year later, so it should be the same. I dunno if i would do it outside though, i might try and con a friend into doing it in his heated garage
Old Jan 3, 2005 | 11:52 AM
rangefinder93
Thanks Peter, I'm thinking along those lines my self. You didn't have to tear apart that wire loom above the back bolt, or the injection line...?
Old Jan 3, 2005 | 12:21 PM
Peter94's Avatar
Peter94
i think i had to use somthing to move it up out of the way. Its a pain until you get the hang of it. like some wire and string it out of the way. it should make it easier
