Sponsored by: Real Truck
235 tire width to 295 difference
Old Jan 3, 2005 | 04:27 PM
sprtsmn's Avatar
sprtsmn
The stock tire sizes are about 31.5 to 31.7 inches tall.
So a 31 is a little short. How it will affect speedo and ABS is up for grabs.
The 265 width is about 10.75 inches wide. So the 10.50 will be a little narrower.
So a 31 - 10.50 - 16 will physically mount, but it will be shorter, and narrower.
I hope this helps your decision.
Old Jan 3, 2005 | 07:20 PM
Davemcfarland's Avatar
Davemcfarland
Thank YOU
Thanks. it helps a bunch.. the bfg long trails are rotten in the mud and are just OK in the snow.. I am torn between mudterrains and allterains.. I will let yall know.. Thanks again.
Old Jan 3, 2005 | 08:46 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Dave M,
If good traction in mud is what you're after, get the Mud Terrains, not the All Terrains. I have the All Terrains and they do excellent in all terrains...., except mud. The tread lug spacing isn't wide enough and they pack up with mud quick and don't like to clean out well. The MT's clean up much better.
The drawback to the Mud Terrains is they don't have siping like the All Terrains and aren't as sure footed on wet pavement and ice. They are also noisier and don't last quite as long as the All Terrains. Still a good tire though if your truck sees alot of mud.
Old Jan 3, 2005 | 08:51 PM
Davemcfarland
What kind of milage can I expect from mud Terrains .. I am new to the f250.. Now on my ZJ I had the all terains and had 82 k miles and they were good for another 15 but I traded it in on the f250..
Old Jan 3, 2005 | 10:28 PM
Waxy's Avatar
Waxy
Originally Posted by tarscraper
Rockwell,
Let me throw my hat in the ring. I went to 285/75/16's. Check out the gallery. You won't like the look of 265's either. They look too small. 265's were standard on my truck. The 285's are a perfect fit on a standard rim. 1" taller than my OEM's.
Hey Rockwell. Welcome back.
I completely agree with tarscraper.
There's no need whatsoever to worry about putting on 285 or 295 75-16's on your stock rims. (I think you just had a typo when you said 295/85-16's, I've never encountered that size.) They will fit no problem, they'll wear evenly, you don't really give up any weight capacity, and they're only ~1-1.5" taller in DIAMETER. Actual ride height change (RADIUS) is pretty minimal. They also won't throw your speedometer/odometer out by more than 1-3 mph at 60-65mph.
In short, I don't see a down side other than slightly increased fuel consumption, and it's worth it for the appearance.
Waxy
P.S. I'm running 285 BFG A/T's on my truck, check my gallery. I've got about 45,000 miles on them now, and I'd say they're about 25-30%. I figure I'll end up at around 60,000 miles. Not bad, and they've worn beautifully even at about 50psi all the way around.
Hope this isn't too late!
Old Jan 4, 2005 | 01:18 PM
hisjr's Avatar
hisjr
go to www.1010tires.com and you can bring up all of the tire specs and compare tires with there tire calculator. http://www.1010tires.com/TireSizeCalculator.asp
Old Jan 4, 2005 | 02:10 PM
spartan's Avatar
spartan
I used to run 35 X 12.5 BFG AT's on 16.5 X 9.75 wheels. I went back to my stock rims and 295 75 16 Nitto Terra Grapplers last fall. I'll never go back to big fat tires or BFG's. The Nittos are a superior tire for wet, dry, ice or snow. The 295's will fit and run fine. Just pay attention to air pressure for good contact patch.
Old Jan 4, 2005 | 04:33 PM
Rockwell's Avatar
Rockwell
Again, I cant thank you all enough for your info/comments/opinions! totally awesome!
After reading Tarscrapers post and looking thru his gallery as well as Waxy`s Ive decided to go with the 285-75-16 size. The place we have our tire work done on our big trucks has given me a price of $135.00 per tire for A/T Coopers mounted and balanced. Granted they arent top of the line, but I dont need them to be as I do not haul or offroad.
MANY thanks again all!
Old Jan 4, 2005 | 06:45 PM
tarscraper's Avatar
tarscraper
Congrats Rockwell! Smart decision for how you use your truck. Post some pics later if you can.
Old Jan 4, 2005 | 08:31 PM
f2fitty's Avatar
f2fitty
For whats it worth I just bought Pro Comp All terras 315's, claiming 50k on the tread. I beleive Cooper makes Pro Comp so you probably have a prety good tire. Good luck.
86F250
18
Nov 9, 2023 03:52 PM
78Southwind
Nov 12, 2016 06:52 PM
Glittle
6.7L Power Stroke Diesel
13
Apr 1, 2015 01:08 AM
BigWhite76
Feb 16, 2015 10:35 AM
Clint40
Apr 28, 2014 06:12 PM
