fuel problem
Old Jan 2, 2005 | 11:58 AM
s.bittner's Avatar
s.bittner
fuel problem
My mass air 94 f150 has an intermittent fuel problem, it will run fine them suddenly start running extremely rich, to the piont of missing and a strong smell of raw fuel. I have replaced the pressure reg. EGR valve, and idle air control valve. I have also seen it do this on hard braking and cornering sometimes. all my connections seem tight and I cant find any vacuum leaks.
It is not generating a check engine light. Could I have an injector sticking open? Any help would be extremely appreciated.
Old Jan 2, 2005 | 12:32 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
