Bronco II Ford Bronco II
pick-up help
Old Jan 2, 2005 | 09:45 AM
1fast5.0's Avatar
1fast5.0
pick-up help
this morning i tried to repace the pick up in the dist.i am haing a problem getting the dist.apart to get to the pickup. does anyone have the drawings to take the top part of the dist. apart? i have the cap , the button, and the plate that makes contact with the pick up off but i can't get the plate that holds the pick up on off.help?????
Old Jan 2, 2005 | 08:59 PM
Monty06's Avatar
Monty06
dist help
in order for you to take off the pick-up coil you need to take out a small pin that hols the oil gear in place use a punch or a small screw driver.
