5.4 van missing
Old Jan 2, 2005 | 07:14 AM
jessej's Avatar
jessej
5.4 van missing
i am new to the forum so bear with me if i am making a few mistakes in posting.
my problem is with my 99 e150 van with the 5.4 engine.after driving about 500 or more miles it will start missing when accellerated in overdrive.i have changed plugs(napa double platnum)switched cops(used set)and problem hasn't changed.problem comes and goes.if it was a bad cop it seems as if it would stay or at least miss when engine is cold at some point.engine runs fine until on a long trip.it has done this about 4 times in the last year.engine light is on now but haven't had time to take it in for reading yet.truck has about 110000 miles on it.when it sits overnight it runs good again until next time.
thanks
jessej
Old Jan 2, 2005 | 07:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about these engines; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 2, 2005 | 11:20 AM
LxMan1's Avatar
LxMan1
Welcome. I would start by changing the fuel filter and cleaning the MAF. I also wonder if it is actually torque converter clutch chatter. Has the tranny fluid ever been changed or flushed?
Old Jan 2, 2005 | 01:25 PM
jessej's Avatar
jessej
definetly not clutch chatter.i will try changing fuel filter and cleaning the maf unit.
thanks
jessej
Old Jan 6, 2005 | 09:32 AM
SCrew55's Avatar
SCrew55
Check cop or plug boots.
