Camshaft Position Sensor
Old Jan 2, 2005 | 12:48 AM
rainking's Avatar
rainking
I have a 96' 2wd 3.0l Ranger. It has recently been difficult to start. The fuel injection has been serviced less than 10,000 miles ago and spark plugs have also been changed recently. The check engine light has now come on as well. I went to autozone to have the codes read and the code said Camshaft Position Sensor malfunction.
So I went ahead and got a new sensor. Upon looking in the Chilton I realized changing the sensor was a little more involved than I thought. After more consideration I was wondering if anyone knew of something else that would cause the computer to give that code. Could a problem in the fuel line or with the fuel pump cause this? Is there something more simple I should try before replacing the Camshaft Position Sensor?
I was thinking about changing the fuel filter to see if that made a difference. It was changed about 30,000 miles ago.
Thanks
Old Jan 2, 2005 | 07:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 2, 2005 | 10:31 AM
rangersvt04's Avatar
rangersvt04
If the sensor went bad then its easy to change out. Just pull the two bolts and disconnect the wires that run to it. Now if the sensor is all chewed up then you have to replace the whole shaft and sensor. Its not that big of a project. Just follow the books instructions. For the sensor your looking at $10.00 for the snesor. For the shaft, wich is a ford only item. It can be from $185 (what i paid for it) up to +$400 is what some of the closer stealer ships wanted for it.
Old Jan 2, 2005 | 10:32 AM
rangersvt04
try this link for more help https://www.ford-trucks.com/forums/s...hreadid=202004
Old Jan 2, 2005 | 11:26 AM
rainking's Avatar
rainking
If I am only replacing the sensor, do I have to worry about findind TDC and using the "special tool" to align the shaft? I was a little unclear if that procedure was for replacing the sensor or the whole shaft.
thanks
Old Jan 2, 2005 | 03:36 PM
rangersvt04
if your just replacing the sensor then no its just remove and replace.
but what normaly happens is the metal pick up bends and destroys the sensor
so the shaft needs to be replaced. as far a the tool. i just called around the parts stores. it was like $35
Old Jan 2, 2005 | 04:02 PM
rainking's Avatar
rainking
Yes, after my last posting I discovered that the metal pick up is bent. Any idea where I might find a shaft to replace it?
Old Jan 2, 2005 | 04:05 PM
rainking's Avatar
rainking
I was able to put the old sensor back on and started the truck fine. The check engine light is still on of course. Will I be doing the engine harm if I continue to drive the truck even just a short distance to a shop or to go pick up a new shaft?
Old Jan 2, 2005 | 04:55 PM
rangersvt04
about the only place your gonna find a shaft is from ford. its gonna run you anyware from $185(what i paid for mine) to +$400(dealer down the street from me).
as for harm to the motor got me. i really dont see that it could but you never really know.
Old Jan 2, 2005 | 05:05 PM
rainking's Avatar
rainking
Where did you get yours? Thanks for all your help. I'll try and find one and get it put in.
Old Jan 2, 2005 | 07:43 PM
RangerRuss's Avatar
RangerRuss
I have been getting the sensors - shaft and all - from NAPA for considerably less cost than Ford. They are listed in the NapaOnLine website however the local NAPA jobber charges me considerably less.
Russ
Old Jan 2, 2005 | 07:49 PM
rangersvt04
got mine at village ford here in MI
Old Jan 2, 2005 | 09:46 PM
rainking's Avatar
rainking
I'm having troublre finding the shaft at NAPA online. I keep getting errors no matter what I click on. Does anyone happen to have a part #?
Old Jan 2, 2005 | 09:59 PM
RangerRuss's Avatar
RangerRuss
Their website seems to be misbehaving or is receiving its periodic LOF ha ha. Napa calls it an Ignition Camshaft Sensor. It is an Echlin part. When their website has its new filter and oil installed I'll try again for you.
russ
Old Jan 2, 2005 | 10:08 PM
rainking's Avatar
rainking
I was able to find the sensor. I was wondering about the shaft. In the Chilton there is a diagram that points to a camshaft sychronizer but I can't find anything under that either.
